You do not mention where the transformer is located. On top I might agree.
On the bottom probably put up a fight on the issue.
To me a penetration is just that a place to leak, weather that be dust, fumes, water or some other liquids.
I looked up your spec and there was a exception for power supplies as I read the text.
What are you going to do about the other penetrations?
There are several methods of maintaining the integrity of the cabinet.
Sealing lock nuts, inside and out.
Meyers hubs come to mind
I saw a guy weld nipples on the bottom of a cabinet once. Welded inside and out.
I believe Hoffman used to have a chart for power supplies inside the cabinet. X kva required so much bigger for the heat.
Coming from the mining industry were it had better be bullet proof. I used to design control cabinets frequently for different environments. We found keeping the penetrations on the bottom and Meyers hubs gave us the best chance at survival. We installed the power supplies inside on feet on a back plane. Never mounted a cabinet solid on a wall, always used unistrut so the back had some ventilation. I live in Arizona which is brutal on temperature and general environment.
We built 4 SS monitoring cabinets for the evaporation ponds. Required by EPA.
Cabinet, battery, solar panel, sensors and radio for the telemetry
Used the best stainless I could find, put the thing together with plastic unistrut and nylon screws. Best we ever got was 6 months before the solar panels died. Everything was eaten and we tried again. Became a constant build project as the customer wanted these installed next to the waters edge.
So you want to know what an evaporation pond is. After the leaching solution has reached its life. It is pumped into a pond for evaporation.
Leaching solution commonly called "water" in the mining industry is made up of H2SO4, water and secrete sauce. I say secrete sauce because depending on the ore, it would change. We had a rail head and would go through 40 tank cars a month of H2SO4. Not counting the semi's that delivered it around the clock.
All of this is for the SXEW building where the copper is plated on cathodes, solvent extraction electro winning.
the big blue space is pond. I am not sure if the zoom I chose will work so the pond is to the east and close to the freeway near the words Green Valley, a retirement community
★★★★☆ · Mine
www.google.com
This is not the largest open pit mine for that look up Morenci Mine which was the largest in the USA when I worked for them.
