Home inspectors know **** about anything. Nothing wrong with that at all.fxrguy said:I have a friend who had a "home inspector" write him up for a 240V circuit that is using the neutral/white conductor as one of the phase conductors. He says it is marked with black phase tape. My question is if this is code compliant?
X2....:thumbsup:Home inspectors know **** about anything. Nothing wrong with that at all.
Get in touch with the HI and read article 200 together.What code reference might address this so he can "educate" the inspector?
:thumbsup:found it! 200.7c1
I though I was the only one who did that............has to be a real Sharpie though, none of this Chinese crap.I usually strip the wire down to the copper, and color it black with a sharpie
A white insulated wire is NOT a NEUTRAL until it is installed and marked accordingly if it is not used as a neutral conductor. Mark it as you want it to be.I have a friend who had a "home inspector" write him up for a 240V circuit that is using the neutral/white conductor as one of the phase conductors. He says it is marked with black phase tape. My question is if this is code compliant?
I love home inspectors, they write up frivolous things constantly. There's nothing better then getting a phone call for retagging a wire or a double tapped breaker. They can make-up all the code they want, I'll just keep cashing checks.:thumbup:I have a friend who had a "home inspector" write him up for a 240V circuit that is using the neutral/white conductor as one of the phase conductors. He says it is marked with black phase tape. My question is if this is code compliant?
They don't always make stuff up. A lot of the times they're mis-informed. They're not getting anything by "making stuff up."I love home inspectors, they write up frivolous things constantly. There's nothing better then getting a phone call for retagging a wire or a double tapped breaker. They can make-up all the code they want, I'll just keep cashing checks.:thumbup:
Are you suggesting that if, as a lot of resis do, use a white as a hot, that it is illegal to tag it as a hot if possible?Whoa whoa. What about nothing under the size of #8 can be re-identified.
What size is the conductor?
Does that make a difference?They don't always make stuff up. A lot of the times they're mis-informed. They're not getting anything by "making stuff up."
Within a cable assembly it is compliant. I can't imagine running an 8/2 to a 20 amp A/C just to meet your rule. Or a 14/3 with a "extra" white wire doing nothing.Whoa whoa. What about nothing under the size of #8 can be re-identified.
