Supply house gave me a Chinese multi-meter. Good thing it was free!!
You have to appreciate the directions:
5. Maintenance
5.1 Battery Replacement
5.1.1 If the sign 'LO BAT' appears on the LCD display, it indicates that the battery should be replaced
5.1.2 Loosen the screw fixing the battery cover and remove it
5.1.3 Replace the exhausted battery with a new one
5.2.1 Fuse rarely need replacement and blow almost always as a result of operator's error.
5.2.2 Loosen the screw fixing the battery cover and remove it.
5.2.3 Replace the blown fuse with ratings specified.
5.3 Test Leads replacement
5.3.1 If the test leads be damaged, it must be replaced
5.3.2 Loosen the screw fixing the battery cover and remove it.
5.3.3 Anew remove screw on the rear case and open it.
5.3.4 Then strip the wire and solder it at the position as aboriginal. :laughing:
5. Maintenance
