More perplexing info:
Just went out and did some more testing.
1. Put the heater in a trough that had ice to be certain the thermostat remained on.
2. For chuckles, measured the current from water to ground and from the 3/2 plug tab to ground which of course were the same at 0.2 volts AC.
3. Then turned off the current at the outdoor 20 amp GFI. The water to current voltage disappeared.
4. Removed the 3/2 with the 20 amp GFI breaker still turned off. The water to ground current measured 0.7 volts!
So there's some with the ground plug removed using the 3/2 plug, but considerably more with the ground in play.
So maybe there is (some) eddy current plus some stray current from somewhere getting into the ground?
If any wonders why worry about tenths of a volt, some animals, particularly horses, are very sensitive about voltage and won't drink if there is any at all.
I'm thinking the 0.2 volts will allow the me to drink but not the 0.7 volts. Using the 3/2 they won't be protected if there is a fault in the heating device.
So now I'm wondering if a ground wire in the water to earth ground would protect them if a fault in the device did occur which is not likely.
