I am looking at some plans for an aircraft hangar job. They are calling for a static discharge grounding grid, and reference NFPA 409 in the specs.
Each hangar bay will have (2) floor mounted receptacles ERICO B165 where one can "plug in" a cable and attach it to the fuselage of the aircraft to prevent static charges from building. These grounding ports will be interconnected with bare copper wire cad-welded together into a grid, and finally terminated to several 3/4 x 10 ground rods.
They don't tell my what size wire to use -- only to check NFPA 409. Is there something in there that I need to know that is not part of the NEC?
