I had used the profile cutters that come on some strippers, but they were damaging the conductor’s insulation.
I have the Kleins too. I squeeze them hard enough to score the jacket then bend it to snap it off. The sheath scrap that comes off is good for labelling wires.I use the klein curve NM strippers that look similar to the ideals above. No damage to insulation and super fast.
Trick is to sqeeze the NM cable, do a little wiggle, remove the stripper and pull off jacket. No damage, clean cut, super fast.
That is what I was first trained on. Used it for house wire and 500kcmil, everything in between.I use one of these for all cable from NM to Teck. Only the last 1/2" or so from the tip is sharp, the rest of the blade is not. I often hold the blade in my hand without getting cut.
Whatever you get use to I guess.
Back in the 1970s, there was a wire company near where I am that use to put some kind of softener in the jacket which made it strip easier in the winter. Come summertime if we had any left over, the cable ripper would just bunch up and not skin the jacket. If we used the summer romex in the winter the cable ripper would not dig into the jacket. I am not sure if it was Cerro wire or Colonial.Never heard of seasonal Romex. I don't think it would ever happen that there wouldn't be stock left over for the next season. Just not economical to manufacture. If you have been seeing what you say I think you have been getting nasty Romex too.
-Hal
This is what I use. I put my cable into the box first, staple or otherwise secure it, tighten the clamp if the box has one. Then I grab the cable tail, go in with the knife right up to the clamp and slit the sheath down the middle. I separate the conductors from the sheath then reach in with my d ykes and cut the sheath off. For some reason I like that better than stripping it before putting it into the box.That is what I was first trained on. Used it for house wire and 500kcmil, everything in between.
Later moved to a newer version of the same type of blade but foldable. View attachment 172815
I used this or a utility knife, I was just curious about what others use.View attachment 172816
This is what we use to use. What I use now is a pair of diagonal cutting dikes.
Take me as your apprentice and you can supervise.I had an opportunity to go to the Bahamas for work but based on the last two days I may pass.
