I’m not an electrician. Never bent or run conduit prior to this project. Thought you might be interested in seeing conduit in resi.
Sorry for posting as a non sparky.
No. I feel like it’s a safer install that protects against rodents. Also I’m redoing all the plaster so I don’t want to ever have to break the plaster to redo something. Also Unlikely event house needs rewired for lightning strike/etc.Are you in Chicago? Why pipe a house?
I was going to close the thread, but it sounds like you're okay with it staying open?Compliments-- you did a great job especially if you never bent pipe before. I just want you to know that this site is not for diy'ers so we wouldn't be able you should you need it. You are free to peruse the forum all you want.
Romex is acceptable in residential because of the fire rating of the building. What sense does it make to have conduits that can last hours in a fire if all the wood studs holding them up are burned quickly. I even see romex in some small commercial buildings with wooden roof systems.It’s kinda funny our commercial buildings use conduit while our dwellings where we sleep are romex.
Well, if a rodent chewed wire started the fire, with conduit, neither the framing nor the wiring would have burned, would it?Romex is acceptable in residential because of the fire rating of the building. What sense does it make to have conduits that can last hours in a fire if all the wood studs holding them up are burned quickly. I even see romex in some small commercial buildings with wooden roof systems.
Yeah I agree, there is way worse things he could waste his time and money on. But I would expect rodent-wire-chewing house fires to be on the decline with arc fault breakers though. I think all the EMT looks excellent, I'm always impressed when I see that guys took ALOT of time to piece together a system like that. But I hope he doesn't lose the pictures on his phone, because when the wall finish goes up it'll just look the same as my house.Well, if a rodent chewed wire started the fire, with conduit, neither the framing nor the wiring would have burned, would it?
People go back and forth whether the Chicago area really has significantly better fire risk due to conduit but it has to be some advantage.
You can avoid some arc faults, and maintenance / changes are obviously easier.
If he wants to wire his house in conduit, there are MUCH stupider things people spend their money on, I say go for it.
Maybe a metal box and or conduit could contain an electrical fire and not spread it to the wooden studs before the smoke is noticed?Romex is acceptable in residential because of the fire rating of the building. What sense does it make to have conduits that can last hours in a fire if all the wood studs holding them up are burned quickly. I even see romex in some small commercial buildings with wooden roof systems.
Works about as well as a quick prayer as you are falling off a roof!LOL ... Arc-fault breakers actually detecting arcs 😂
Oh so true and some mods just let them ride rather than offend someone that obviously has no reading comprehension skills when signing up.Is it just me or do there seem to be a million of these homeowner threads now? Maybe I’m just here a lot more but it feels like a lot more than say years ago.
What is the point of entry rules if they aren't followed?
