Not if at all avoidable.So you never use plastic boxes?
I like 4"x4"s with mud rings, mc, and pigtailing for devices.
Yes they splash a lot of civil suits around. That'd why I said successfully litigated. I agree with splatz that we don't need to hide behind some faux reason for disallowing weekend warriors. Just needing a professional forum is reason enough. But I think that, sometimes the diyers offer good content ( such as the OP on this thread) and restricting discussion on a worthwhile topic because of who initiated the discussion seems a bit churlish.It only takes once!
When someone is hurt lawyers sue everybody possible.
So what I'm hearing is put conduit seals in, and use this stuff? If it's worth overdoing it's worth going WAY WAY overkill right?? LOLA half inch pipe with 3 wires in it is a freeway for mice to get to the 4 square condo . You would be amazed at how many chicken bones I've pulled out of switch boxes . Rats are sneaky bastards too .
Im not putting you or the work done down . Just saying a chain is only as strong as its weakest link .
so you’re saying I should use explosion proof fittings typically used in gas station electric? 😂Nice work but .
The old rodents can't get to the wire trick . I worked on and built restaurants for 15+ years and A half inch pipe with 3 wires in it is a freeway for mice to get to the 4 square condo . You would be amazed at how many chicken bones I've pulled out of switch boxes . Rats are sneaky bastards too .
4 square condo...🤣
I’ll trust my cat to keep the rodent population in check
I got a couple gallons of cement and fiber if you want it ..
4 square condo...🤣
wait wait wait
I see romex in the picture
did you pull romex in those pipes?
wait wait wait
See earlier post. I was going to run UFb to 3 outlets where I couldn’t get conduit to the outlet from the basement. I since changed plans and have a plan to get conduit to those 3 boxes. Damn homeowner and his change orders. 😂first pic has 12g rolls.
I like them all too but don’t see a need for them in most residential situations.Not if at all avoidable.
I can promise you I’m not in the trade. I have spent an hour or more almost everyday for the past year lurking here and other electrician forums.The more and more I see and read on this thread I’m starting to think the OP is very much in the trade and getting a good laugh out of this. Nice bends, EMT, insulated bushings, THHN, etc.
I will need to bury some uf-b for things like exterior lights. Did I mention lime/sand/hair plaster is no fun?
Diamond blades are your friend. Very messy but a friend none the less.
Cletus is back!The more and more I see and read on this thread I’m starting to think the OP is very much in the trade and getting a good laugh out of this. Nice bends, EMT, insulated bushings, THHN, etc.
With a new way of starting the conversation. No longer "Can I do dis", Now it's "I did dis"!Cletus is back!
