Anyone ever install motion or occupancy sensors with metal halide lighting? If so, did you incur any problems?
I've worked with MH fixture layouts where there was another socket in the shroud that would turn on if the MH lights went out so if there was an accidental opening of the MH circuit a 100 watt halogen would turn on so it wasn't complete blackout. This secondary circuit had a timer in front so the halogens wouldn't turn on when the lights were shut off at the end of the day. Basically just a primitive emergency circuitEBFD6 said:I would think re-strike time would be a major issue with any HID lighting on occupancy sensors. I have never seen HID lighting set up that way, probably for good reason.
carryyourbooks said:Anyone ever install motion or occupancy sensors with metal halide lighting? If so, did you incur any problems?
