Hi Folks. I am in the process of finishing my rough in for new construction dwelling unit. In Laundry room Installed 4 11/16 box with 10/3 nmd for Electric Dryer as per OESC 26-744 2)
Also roughed in for two additional Receptacle as per
26-720 e) at least one duplex receptacle shall be provided
i) in each space where the complete plumbing is installed to accommodate a washing machine;
ii) in each laundry room, in addition to any receptacle specified in Item i);
Homeowner changed Electric 240v dryer to Gas dryer, trying to find code reference if Gas dryer would need a dedicated circuit 120v 15amp Receptacle with arc fault breaker.
Also in basement utility room there is a requirement for Gas water heater and Gas boiler. Gas boiler equipment is not on site yet and as per hvac guy who is going to install it later, it requires a regular 15amp receptacle.
As per OESC Bulletins, i can tap Gas water heater Receptacle from Utility room Receptacle(Installed beside panel)
Do i have to feed Gas boiler with a seperate circuit alongwith arc fault breaker. If someone can hook me up with code reference for gas boiler. BTW Gas boiler is for floor heating. Thanks in advance.
