So I get a call from some friends of my wife that need some receptacles added to some rooms. This throws somewhat of a red flag up because I know this house was built before 1920. Nice plaster walls and ceilings, really could be restored to its former glory. Just as I suspected, a lot of hacks have been busy over the years.
The house does have a new 200 amp service courtesy of a fellow EC that was installed so that a new HVAC unit could be added, although the house is not insulated hardly at all?? Sorry, I digressed. Anyway, I take a look at the rooms where the recepts are to go and things start to go downhill. The only existing wiring in the first room is in a closet area, you have to go into the room then the closet to turn the light on. There is also a receptacle there with a 2 wire lamp cord coming out behind the faceplate and stapled to the wall feeding a single gang old work box screwed to the ceiling with a lamp socket and pull chain. The other rooms are similarly wired and much worse. Trunkslammer quality for sure.
Just out of curiosity I checked the receptacles throughout the house and all if them showed "open ground". I pulled the faceplates and sure enough, no grounds. The old BX/AC cable jackets are not continuous anymore. Total rewire just to make it safe. HO installed GFCI' in bath and kitchen, open ground= not functional. Tested just to make sure, would not trip at all with tester.
HO says that an electrician signed off on all of the wiring being safe just last year!!! Thinking this is BS I ask "Who was it?" and they said the one that replaced the service. He is a friend so I called him to see what the story really was. He only replaced the service, with inspection, and pulled one new MC to a new upstairs receptacle. He did no inspections or sign off on anything. He noted to the HO that there were some problems with the old wiring that needed to be addressed.
Not going back to this one. Rant over, thanks for listening!
