1 - 20 of 34 Posts
Service electrician
Electrical Testing
Electrical Maintenance-industrial, data center (BIG HERE) or commercial
Government Electrician
Generator Maintenance
DC Power, Battery and rectifier installation and maintenance
Fire Alarm Specialist
Solar
Medium/High voltage, splicing, testing and cable location
Service electrician
Electrical Testing
Solar
Hospital electrician
Generator tech
Yea the petroleum industry is huge down here and offshore electricians make huge money but its just not for me. Being away from for 2-3 weeks at a time kinda sucks.
Of course it sucks, that's why they make huge money. I've actually considered doing it myself. My son is 13 and in 8th grade, I'm still young (34). When he's out of school (I won't even be 40 yet), I may look a little more seriously into becoming an offshore rig electrician. It's very good money, and you only work half the year. 21 days on, 21 days off.
12 hour shifts?
12 hour shifts?
I believe so. I have done some research, but not too much. From what I've read most companies do either 21 on/21 off or 28/28. When you are on you work 12 hour shifts for 21 days straight. That kind of sucks. However, having 21 days off in a row sounds pretty good.:thumbsup:
From what I understand the crew meets up somewhere and gets on a boat or helicopter depending on where the rig is located, flies out to the rig, works for 21 days and then flies home.
The biggest hurdle for me would be the safety policies. I've never been much on following the rules :whistling2:, and from what I've read these operations have very strict safety rules and regulations. It would definitely require a complete change of attitude and work practices on my part. I don't know if I could adjust. Although for the right amount of money I think I could force myself to stomach the bullsh1t.
· Electron Flow Consultant
Go work maintenance at a Chlor-alkali plant and get some instrument work. The one I worked at had 13.8kv, 11.5kv, 575v, on down to 120v. Then you have DC up to around 300v and 100ka. For instruments, you have Ph, orp, hardness anaylzers, moisture analyzers, and all the usual devices, and more.
1 - 20 of 34 Posts
