This isn't my forte, and I'll understand if Speedy bumps this to DIY, but I don't want to sign up for a new forum, so....
...so, I thought I identified all the problems in the basement from hell but I found another one. Two guys plumbing hooked up an outdoor sconce light outside the main entrance door. It's fed from an indoor pull-chain light in the hallway by some old lamp cord that was probably laying around. That won't fly!
The lamp cord is coming out of the back of the pull-chain light, run along the outside of the wall, then run in between the door and the jam and on into the back of the sconce.
What I propose is to mount a round all-weather box to the outside of the house and run cable inside the wall to the pull-chain's box.
From what I know I'll need to use a healthy dose of sealant around the box and on all the box's plugs. The box and metal parts of the sconce need to be connected to the EGC.
My questions are:
- What type of cable should I use? UF? Or will NM-B be ok because no part of the cable will be exposed? Or something else?
- Should the box be open back or should I wire through a certain type of strain relief?
- Should this be connected to a GFI? I imagine it should be...
At work on the trucks we use Liqui-Tight (LFNMC-B) for everything but I'm not sure that's the way to go here...
OK, thanx!
