1 - 14 of 14 Posts
I'm a first year apprentice and wanted to run something by someone with some more experience. I'd ask my journeyman but it's the weekend.
My uncle asked me if I could extend the light fixture ten feet up with a new motion sensor light.
Its located out front of the apartment complex my family owns.
Should I attach a junction box at the current fixture and run pipe 10' up? What type of box would I need at the end of the pipe to be able to attach the new light fixture. Or is there a simplified way of doing this?
dmxtothemax said:
Is there access to the other side of the wall ? Do you care what it looks like ? Or just want it done cheap as ? Easyest way is to use conduit, But it might not look pretty. But some paint will help there.
It's a brick wall and yes in want it to look nice and flush as possible.
So that leaves really only outside instal, such as conduit,
If you paint the conduit the same color as the bricks,
It will be a lot less obvious.
Can you go up higher ?
closer to the roof,
and drop a cable from the roof space ?
felonious smile.
You will need either a T or Round WP extension box to extend from where your point of power is . Use EMT or RMC on brickwork. Use a round WP box for your new fixture location.
Sent from my C5215 using electriciantalk.com mobile app
Reactions: Stoneage
Motion detectors (the ones I've seen) install on round WP boxes.
WP extension ring, WP blank, round WP box, 10' of EMT, two connectors, 30' of THHN, a couple straps and some plastic screw anchors.
It doesn't get a much more simple :thumbup:
Discussion Starter · #11 ·
dmxtothemax said:
So that leaves really only outside instal, such as conduit, If you paint the conduit the same color as the bricks, It will be a lot less obvious. Can you go up higher ? closer to the roof, and drop a cable from the roof space ?
It's two stories and the attic isn't accessible it would def look much cleaner this way.
fertilizer distrubuter
Can you get this circuit to the attic? Some homes have chases from the attic to the basement.
If it is located low on a gable end you can drill the stud space from the attic above the existing box or from your new light hole. Chisel the light box out from the wall. Cut a 3 inch hole through the brick hole. Then fiber rod down to your old box. check out the depth you can get a rod before you cut the new box. Then quickset mortar in your new box. I would either put as blank over the old hole or leave the motion detector or photocell in it. I have never had to run conduit on the outside or inside (ok I don't channel concrete walls) of a house.
felonious smile.
Should unlicensed apprentices be doing electrical work on multi family dwellings anyway???
I was doing all those exterior lighting installs at a 106 unit apt complex when I was 14, 70 watt hps nema heads, 175 merc heads and 150 watt hPS floods. All those fixtures are still functioning today.
1 - 14 of 14 Posts
