1 - 9 of 9 Posts
What do you do when your panel is going in a finished wall but the meter will be about 2' lower because of grade. Its in a garage so i was thinking about using an LB but wanted to hear suggestions. We have to use pvc, emt for the feeders.
Electrical Simpleton
FWIW, generally, there is no minimum height for a panel. You may not want to lower it because of aesthetics but it is an option.
Pete
animal lover /rat bastard
there's at least one poco around here that won't let you nipple out the back of the meter can (ie. whatever you decide make sure it's kosher).
Senile Member
Put a meter/main outside and then run ser cable to your Sub panel which won't need a main breaker in it now. Bam!
1 - 9 of 9 Posts
