1 - 9 of 9 Posts
i thought i read here once that it was possible to buy just the bus bar etc., to retrofit an existing panel that would be a big pain to replace. I asked my supply house and they couldn't help me. Is there an online source?
Usually cheaper to buy the whole new panel, and then swap the guts. You end up with a new enclosure that you can use on a later project as a junction or structured wiring box.
Ya I could probably just do my own transplant but am I right or wrong thinking that there was a company making a product just for this application?
Right now my customer has 4 of 20 bus bar stabs burnt up and I don't want to mess with their broken stuff.
In the past I have had to retrofit an existing panel with a new buss with more breakers available. I first called on the inspector to make sure that he would not flag me for not having enough room in the panel. I then bought new panels and removed the buss and discarded the empty panel can.
Can't Remember
The only trouble with the retrofits is there is lead time to get them. I have done three and they work well enough. Its great in say an apartment building where you could walk through and check the dimensions of each units panel and make a list of what you need and order it up. At least its really designed for the purpose. I used this to replace Trumbull guts in three panels recessed in concrete.
1 - 9 of 9 Posts
