Hi, this is my own house but I am an electrician so I believe this is fine to post questions about it. This is for Canada but I was under the impression brands are fairly cross border.
Looking for panel brand recommendations for the following 200A service upgrade I will be doing. House is for resale so I am more about cost - anything is better then the current stablok I have. Current story: is I have 100A stablock main service running from the alley behind my house, low over the entire garage roof, then a overhead back to the garage distribution panel, so close to the deck you could stand up on your toes and lick it. This actually works out kind of nice because I can build the new mast and panel on the alley side of the garage, run a sub feed back to the house but hopefully underground, then the utility only has to come once and run 10 feet from the alley because my main is now a sub. That means I can either connect the old panel up for the day or switch out to the new panel if I have time/energy.
Anyways,
Main 200A panel: This panel can be small as I only have lights and plugs, the new 200A sub, and the garage door. What would be a good brand for this? There is a supplier with good prices on General Electric.
The house Sub, still 200A as 95% of the load is off this, including the hot tub. This I was thinking square D because the breakers are so widely available and cheap. I don't need any AFCI thankfully.
Thoughts?
Anyways,
Thoughts?
