Normal voltage leaving the Central Office -48 to -52 VDC. The closer you are to the CO the higher the voltage. I had an office building that shared the same parking lot as the CO, the incoming dial tone was so hot I had to use resistors to knock it down so it would be compatible with their phone system.My understanding back in the day was 48v DC nominal normal state, and 96v AC at 20Hz for ringing, 6-12v DC modulated line in use.
red-right-ring-rough!
Yep, rough or ridge..any tactile.Normal voltage leaving the Central Office -48 to -52 VDC. The closer you are to the CO the higher the voltage. I had an office building that shared the same parking lot as the CO, the incoming dial tone was so hot I had to use resistors to knock it down so it would be compatible with their phone system.
I was taught red-right-ring-ridge.
when we use screw terminals or binding posts, tip goes on the left and ring on the right.Big John said:I don't follow the "red-right-ring-rough." I know tip and ring, but what does the "right" and "rough/ridge" refer to?
Hey Tywrapp you ever use the spit on finger method to test for polarity? Hurts like heck when you get across ring voltage and ground but it is a good trick!Normal voltage leaving the Central Office -48 to -52 VDC. The closer you are to the CO the higher the voltage. I had an office building that shared the same parking lot as the CO, the incoming dial tone was so hot I had to use resistors to knock it down so it would be compatible with their phone system.
Ring side of the circuit...I don't follow the "red-right-ring-rough." I know tip and ring, but what does the "right" and "rough/ridge" refer to?
Never tried that! My way to rest for polarity was to take one lead from the head set to ground and the other lead to each conductor until I drew dial tone.Hey Tywrapp you ever use the spit on finger method to test for polarity? Hurts like heck when you get across ring voltage and ground but it is a good trick!
Most likely a Special Circuit (T-1). 180 voltsI am reading this thread and I could be reading another language. I never deal with phones anymore and when we do it is resi stuff.
I did get knocked on my butt under a commercial building when I ran into some phone wires hanging there -- I assumed there wasn't much voltage there--- surprise
Well its supposed to be 48V, but some add around 9V to run pagers off the line!:whistling2:Just curious what the phone voltage at terminal block should be..
I get 57VDC when line is in stand by mode...
Seriously?!?Well its supposed to be 48V, but some add around 9V to run pagers off the line!:whistling2:
:jester:running joke with B4T:jester:Seriously?!?Link?
