Status
Not open for further replies.
1 - 5 of 5 Posts
I use simple store bought PIR' for activating lights in my shop to scare people away, lately I wanted to have a bell go off too BUT the output of the pir wont ring the bell, is this an inductive load? the little red wire of the pir only outputs about 104 V ac which will turn on the resistive load of my lights but not activate the transformer for the bell? am I missing something? or do I somehow need to boost the power output of the PIR? someone must know the answer, thanks Steve
Connect 480 volts to the microwave. Then put the buzzer inside that. Should work ok now.
Reactions: Metersocket648
residential, commercial, and industrial
That's called an RIP when you connect it that way, macmikeman.
No, no, you got it all wrong @macmikeman , you have to take the HV transformer out of the microwave, and THEN connect 480 volts to it, then get a second Microwave transformer and put it in there and then the buzzer will work🙃🙃
Elechicken!
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to Register.
1 - 5 of 5 Posts
Status
