1 - 20 of 59 Posts
I'm bored and wanted to write some PLC programs.
I'll start with a simple program and progress through advanced topics and techniques. Email me with real life examples to program.
If you have a better mousetrap, let me know.
Simple 3 wire control
Why the CR? I like to keep the outputs separate from the logic.
Coaster Sparky
Two proximity sensors that have to be in agreement with each other within 5 seconds, or it throws a fault.
Just something I see on a daily basis. I don't write program though, interested in picking it up.
Coaster Sparky
dronai said:
This is not correct yet, still working on this one.
I've got it drawn out in our shop, I'll take a look at it tomorrow. I'll throw it together in MSpaint when I have the chance and post it back here.
Reactions: dronai
Why did you use an error state, and a fault light ? I'm loading yours now to test
And what is the clear on rung 1 ? Never used that
Discussion Starter · #13 ·
It clears the memory.
Its good programming practice to use a binary bit instead of going directly to output.
You wanted the fault light to come on if the 2nd prox sensor did not detect an object within 5 secs.
Discussion Starter · #14 ·
Run Jog Selector Switch
Run and Jog Control
We use a selector switch to set run or jog mode.
Run mode will set the seal in bit 1:1/4 to 1 (on)
Jog mode will set the seal in bit 1:1/4 to 0 (off)
Your reset button does the same job as the clear memory doesn't it ?
Just clears the fault light. You don't want that light on all day long.
Regarding the Clear instruction:
I see that, I just couldn't find any logic that would stay in the memory after the seal in circuits are dropped out by the NC contacts.
Discussion Starter · #18 ·
s:1/15 the rung will only run once when the program first starts. It is called a initializing bit.
clear == MOV 0000H --> B3:0
so for example:
my B3:0 has some random data 1001 0001 1111 1000
the clear instruction will do this 0000 0000 0000 0000
You guys are thinking like electricians. U gotta think like a programmer. Just cause its ladder logic doesnt mean relay logic.
Put the two prox switches in seris with xic`s with a tof instruction. then use the dn bit to trigget the alarm.
Discussion Starter · #20 ·
Can I see some code.
1 - 20 of 59 Posts
