Only if you replace a 2 prong receptacle with a 3 prong protected by a GFCI. Otherwise it isn't required as far as I can remember.Hi,
I might be wrong, but is there a code reuirement that plugs installed on the load side of a GFI plug must be labeled so user is aware what is on GFI?
thanks
