1 - 10 of 10 Posts
I’m working on a bunch of pole lights that are 400w metal halide. The voltage is 480v. The old ballasts had an igniter with em. The new ones do not have an igniter, just a cap. The new ballast kit and lamps I’ve got are both m59. I wired one up and it trips the breaker immediately. Checked for ground faults on the ballast already nothing is faulted to ground. Any suggestions?
Wrong input voltage on the ballast? Wrong label?
With out picture its hard to tell. 480v is generally special order as no one wants to make them so i would check the label first.
The other typical problems include
1/ bad wire up the pole (you moved this around wiring in the new ballast)
2/ mis-wired as people forget common on 480v is a phase (happens more often on a photo cell)
3/ lamp holder shorted to ground
p.s why trip the breaker when fuses and fuse holders are cheap and make troubleshooting in the future so much easier.
This post reminded me of my favorite code question:
What is the minimum height of a high pressure sodium luminaire with a 480 volt ballast in a parking lot?
So what is the answer?
Any suggestions?
Yeah. Next time, don't assume :)
You wired it up and the breaker tripped. That means the fault was existing.
When a breaker trips you first find the source of the fault. Often it is a ballast but, even if you narrow it down to one pole, there are still a few other opportunities for the wiring to be bad.
PS. I ALWAYS hated 480V light poles. You are often (usually) working on them alone and hot and I don't like the idea of dealing with 480 volts installed by who knows who, inside a steel enclosure, right at eye level, 20 feet off the ground, standing in a little bucket. Simply opening the cover and pulling on the wires can cause you to at least schit yourself.
1 - 10 of 10 Posts
