Take a long lunch now!:thumbup:Are those variable speed pool pumps worth the money? And is the idea to let the pump run longer at lower rpm?
Also, what level hack on the hackometer am I for not using a pool jbox but this gutter instead?
When's lunch?
I have my pool pump on a timer to save money.. only run it as much as I need depending on temperature and usage.
The gutter was like $50.How much did that gutter cost? I dont work on pools, but I have hooked up one of those "pool j-box". They didn't seem very expensive, but i think they only had room for 2 or 3 conduits.
I thought variable speed motors/pumps were only for 3 phase applications, but i dont know and I'd like to hear the answer to this as well.
Do you know how much those pool j-box's cost?The gutter was like $50.
When's lunch?
How is a pool junction different from any other 3r junction box?Do you know how much those pool j-box's cost?
Its this funny looking black LB-shaped box, and its got a bonding bar in it.How is a pool junction different from any other 3r junction box?
Although VFDs for single phase motors do exist, they only work on certain TYPES of single phase motors, and they cost so much that it's rarely worth it. But other than that, you are right, they are mostly for 3 phase motors....
The variable speed motors for pool pumps are used as Jraef said sometimes for the sweep.Are those variable speed pool pumps worth the money? And is the idea to let the pump run longer at lower rpm?
When's lunch?
Bending over to pick up tools and then throwing them back in the dirt is rookie... You should get a rolling cart...
What are you worried about?pfactor2 said:What voltage/s are present in the gutter?
Are you gonna mount the gutter at least ?
