Hi,
I am missing something. I have a powerflex 70 with remote HIM which is currently being used to start and stop a pump. I want to control the drive using 2-wire control with a jog reverse. The wiring has been completed as in the manual with the necessary parameters being changed. But here's the problem, I want to use the HIM to give the speed reference. When the buttons are pressed I can see the dissection change, but no speed output in either direction. Is it possible to have 2 wire control and HIM for speed? Or do I need to connect a pot?
Thanks all
C
Thanks all
C
