1 - 20 of 33 Posts
Any of you guys here pre fab stuff before going out. I usually make up alot of stuff for services before heading to job site. Here's an insteon smart switch with override switch that I fabbed. This didn't take me but 5 minutes but I got do it while watching TV ..thumb up....
RIP 1959-2015
Good idea:thumbsup:
What's that switch do?:blink:
Discussion Starter · #11 ·
HARRY304E said:
Good idea:thumbsup:
Its a smartlinc switch for the insteon system. It's dual band so it is backwards compatible with x10 systems or will work wirelessly on the new insteon system. I'm using it to run a control circuit for a bagel oven. The guy wanted full control over the timer to turn the oven on and off and wanted remote capability to turn it off if they open late.
I do. I pre-build all my panels, including tying them in if there aren't a ton of circuits, or the wires will need to be extended. I put a movie on in the garage, turn up the heat and do it the night before. When I show up it's just tying in the mains and splicing the branch circuits in the JB's.
On this one, none of the circuits were grounded so I've got my 7 GFCI's (cheaper than deadfronts or breakers) ready to be connected on the load side.
In the olden days, doing new construction resi production work, we would make up spiders........simply a ceiling box with four hots and a switch leg made up.
Nail up the ceiling box, drop the legs into their places and your room was done in 5 minutes with make up in only one box jumpered to/from the next room.
SteveO. said:
I do. I pre-build all my panels, including tying them in if there aren't a ton of circuits, or the wires will need to be extended. I put a movie on in the garage, turn up the heat and do it the night before. When I show up it's just tying in the mains and splicing the branch circuits in the JB's. On this one, none of the circuits were grounded so I've got my 7 GFCI's (cheaper than deadfronts or breakers) ready to be connected on the load side. http://s27.photobucket.com/user/steveogs/media/ca04ddc0.jpg.html
Why do a panel gfi when you have 7 gfi's at the panel already?
Slave to the grind
I used to work for a company that did a lot of hotels and motels. All the rooms were block walls and the same as far as receps and switches went.
On rainy days, we would be at the shop, bending and cutting conduit and, attaching the masonary boxes. We'd load these contraptions up and take them to the job. Once the blockies hit the level we were in, we'd set our pre-fabbed deals into place and walk away. It was a great time saver, especially when there were 15-20 blockies and only 1 or 2 electricians.
So you could plug a fridge, freezer or anything else in and not have it sharing a circuit with the rest of the house? CEC says you need a utility room circuit that doesn't feed anything else but the stuff in that room. Obviously, the 7 plugs are feeding through to other circuits.
Gold Member
Obviously this is an upgrade, so you don't have to add that utilty room cct. Making that a totally valid question.
You're assuming there wasn't one in there before, or that the customer didn't ask for a place to plug something in. If you install a new panel and don't add a receptacle near it, you're a hack.
I appreciate all the guys with nothing better to do than to criticize what is most certainly code compliant or better.
1 - 20 of 33 Posts
