Finished up a house about a week ago and I get a call about one of the AFCI breakers keeps tripping. Went and checked it out yesterday and it would automatically trip when turned on with no load on the circuit. Figured I would put the circuit on the AFCI that is installed above it. Waited about five minutes talking with the homeowner and it didn't trip. Decided it was a bad AFCI breaker, went and got another AFCI come back and it's tripped. Went ahead and replaced it and put the circuit on the new breaker. Flipped it on and all it well.
Got a call this morning that it is still tripping. Went out and wasn't going to mess around with this much more. I ended up taking the receptacle out that the homerun is on and wing-nutting the homerun wires. Flipped the AFCI back on and works fine. Went ahead and waited and got some work done on the laptop that needed to be done. 1.5 hours later the breaker trips about the time the GeoThermal Unit kicks on, which had kicked on/off about 4-5 times in that 1.5 hours. I reset it and get back to work, it ends up tripping about 45 minutes later.
I've checked the wiring in the panel and outlet box, neither are cut into the insulation. I'm just not really sure what to look for on this one, instead of running a new homerun which I'm really trying to avoid. Have any of you had this sort of problem? The only things on this circuit are 10 switched receptacles that go around a bedroom. Could it be the AFCI itself?
