You call those zap straps?Those ladders are zap strapped together and at a 4 to 1 angle, and there's a safety person holding the one leg at the bottom.. it's completely safe!
Cable ties.Yeeeeeeeeeeeah boooooooooy
what do you guys call them?
cable ties, what planet are you from?Yeeeeeeeeeeeah boooooooooy
We use cable and tray/catenary wires because wires and pipe is unnecessary unless it is necessary, haha.cable ties, what planet are you from?
id probably do that too, but id put a good friend at the bottom of the ladder, not the helper i just got done yelling at.Funny part- I would probably do that. No Fear. I kinda always got off on climbing up crazy insane things work or not.
to what?I'd zap strap the bottom too...
16d nails hammered into the tarmac.to what?
what is a tarmac. the bottom of that ladder looks like its in a bush. I suppose you could zip tie the ladder to that guys leg.16d nails hammered into the tarmac.
Bitumen emulsion used as a roading surface. Zip tie it to the bush.what is a tarmac. the bottom of that ladder looks like its in a bush. I suppose you could zip tie the ladder to that guys leg.
I think what we call asphalt?Bitumen emulsion used as a roading surface. Zip tie it to the bush.
