BR-30Can someone tell me what bulbs work with these trims? The cfl br30 stuck out more then inch
http://www.homedepot.com/p/Cree-65W...ht-Bulb-BBR30-06527FLF-12DE26-1U100/204366182
That's what I tried br30 cflHARRY304E said:
There are no adjustments on this particular trim. I'm guessing the short neck lamp may be answer will know tomorrow.meadow said:A lot of these often need the socket adjusted via thumb screw.
I hear you and this is what they wantedsvh19044 said:Read Trim/Can. Select Lamp. It's a PAR 30. And don't you have a more modern choice instead of a 1970's eyeball? But really, PAR 30 is what you need for that trim.
