1 - 20 of 47 Posts
[EQUOTE=butcher733;803860]Just starting in the trade. I would like to hear any feed back, preferably the mean pointless kind.:)[/QUOTE]
Re identify white wires on double pole breakers! Good job though!
Discussion Starter #10
Nice work, just missing tape on ccc's.
I asked about that and was told not to waste time on it. Isn't there a code on not re-identifying conductors smaller than 8awg? What's the solution if so? 12-3?
Is that a vinstar control panel?
Ems or telephone?
You put that conduit in the telephone terminal space...it's going to get ugly! :001_huh:
Is that a no no? Prints called for two duplexes on separate circuits for that board.
Thanks for the comments.
felonious smile.
Nice, did that value pack panel come with all those tools?
Ems or telephone?
All ccc's need to be re identified. I drill a hole in a large sharpie marker, insert white wire, run up and down the wire a few times. Comes out perfect. Tape looks bad on small wires.
Salty Member
It is always a code violation to mark a white conductor to any other color in a raceway.
In a pipe white must be a grounded conductor or not used at all.
Salty Member
Nice bending practice and it fits but you did ask for comments.
If I had to do it that way I would have moved the offset up to the 90 so the conduit was tighter to the wall.
But I would rather use an LB at the top of the wall, if no LB was on site I would have mounted a 4 square at the top of the wall with it high enough to come out the back of it on top of the structure. In other words I would have used a 4 square like an LB.
Looks good the panel is wired very skillfully:thumbsup: The wires and conduit are actually straight:thumbup:
Only thing I see is the black 8 guage connected to the ground bar and no reidentified whites, but those are easy fixes.
I would have kept the receptacles close to the top of THAT UNPAINTED BACKBOARD.
was there a load calc done on that panel? seems like alot of ampacity for a 100a ml panel
other than that nice work
Ems or telephone?
I was reffering the gray cabinet with the black knobs that say surveyor. My contractor does a lot of family dollar stores and they use them.
1 - 20 of 47 Posts
