It is not a patient care area, it is a waiting room. But still........... there may be some shocking things going on around that place...
That's what I'm saying rather then swap feeds just swap the device with an ip addressable device. Then he can turn them on off left right or whatever he wants with the phone. Programmable.I'm only changing around the feeds for the lights and one receptacle behind the TV. I'm not adding any receptacles or devices.
As for it being a house, it's common around here to have houses converted into doctors offices. Sometimes the entire thing, sometimes just the first floor. In this situation it's just 2 rooms in the basement.
It's a nice setup that this guy has going, very little overhead and probably charges $250/hr.
fify.if he is working out of a house i cant see any rules applying. I however would definetly add tamper resistant outlets since there is a good chance young kids might be coming into that waiting room. An emergency light to would be a nice touch. Other than that all sounds fine.
fify.
What am I missing here? :001_huh: He added even more errors. :laughing:True. :laughing:
meadow originally wrote defiantly instead of definitely.What am I missing here? :001_huh: He added even more errors. :laughing:
Well yaa, I saw that. So far you are the only one that got the "d" word correct. :thumbup:meadow originally wrote defiantly instead of definitely.
As for the other errors, this forum is full of bugs and issues that many quotes have the paragraphs taken away and the sentence pushed together and it also makes the capital letters lowercase![]()
That's because, quite simply, I am awesome.Well yaa, I saw that. So far you are the only one that got the "d" word correct. :thumbup:
Auto correct. How many times it has failed memeadow originally wrote defiantly instead of definitely.
WTF is wrong with mastic pads?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?OK Mr. Mastic Pad.![]()
Or program it from your router as long as it isnt 100 years old. Then you can set the program too.For the TV, can't you just program it from the menu to go on and off ???
