1 - 20 of 42 Posts
Hi all, I was wondering if any of you knows of a efficient method to pull ground rod out? PG&E required from us to pull it out saying it's too close to their gas line. Anything other than good old digging?
· RIP 1959-2015
I'll bet you could drive to the closest Dunkin Donuts,get a coffee,a steak eg and cheese bagel toasted then hit the supply house buy a ground rod and drive it home faster than you can pull one out of the ground..just sayin:whistling2::laughing:
step 1: Use kinpex cobra to tighten crap out of acorn clamp on ground rod.
step 2: Use knipex cobra and grab right under acorn clamp twist and pull up at same time.
Step 3: success
We pull everyone of ours up that we used for temp poles and reuse them on the next one. Works every time with little effort, of course I live in a swamp and can usually push them in by hand too so ymmv.
· Premium Member
Usually a utility has no jurisdiction over contractors, I would tell them that the NEC requires us to be in that spot. Sometimes they say "OK".
1 - 20 of 42 Posts
