if a standard double pole of brand X will fit, then a quad brand X will fit , , legally or otherwise
if a standard double pole of brand X will fit, then a quad brand X will fit , , legally or otherwiseDo quads exist that will fit, legally or otherwise, in a Sylvania box?
Not even close to being true. I'm sure what you meant was "if a standard double pole of brand x will fit in the rejection slots of a load center , then a quad of that same brand x will fit there. " Otherwise , it won't fit, and boy oh boy do I hate running across the ones where the ass clown broke the rejection bar out with his hammer and screw driver, because that always leads to burnt up bus stabs given enough time.if a standard double pole of brand X will fit, then a quad brand X will fit , , legally or otherwise
why would you mention modifying the breaker or panel when i did not ?Not even close to being true. I'm sure what you meant was "if a standard double pole of brand x will fit in the rejection slots of a load center , then a quad of that same brand x will fit there. " Otherwise , it won't fit, and boy oh boy do I hate running across the ones where the ass clown broke the rejection bar out with his hammer and screw driver, because that always leads to burnt up bus stabs given enough time.
Because when you tell somebody that , it is clearly wrong. A regular two pole 20 amp breaker for instance will fit anywhere in the panel where there is two spaces available. A quad won't fit any two spaces available unless they are notched designed for acceptance of twin or quad breakers. Re read your original post with this in mind.why would you mention modifying the breaker or panel when i did not ?
i thought it would be self evident that i meant "fit" like the original breaker for that panel
but i do agree that neither should be modified, because of the buss rating
i stand corrected. and thank you, i did not think of thatBecause when you tell somebody that , it is clearly wrong. A regular two pole 20 amp breaker for instance will fit anywhere in the panel where there is two spaces available. A quad won't fit any two spaces available unless they are notched designed for acceptance of twin or quad breakers. Re read your original post with this in mind.
[OP] Cool. That fits with my observation that "deep throat" quads don't seem to exist.A regular two pole 20 amp breaker for instance will fit anywhere in the panel where there is two spaces available. A quad won't fit any two spaces available unless they are notched designed for acceptance of twin or quad breakers. Re read your original post with this in mind.
