1 - 11 of 11 Posts
1) Is it ok to fit dimmable led lights with dimmable transformer and a non dimmable switch.
2) For a 70w transformer connected to three led bulbs what is the max voltage for each bulb, using 4w led bulbs.
Please could I have some help guys :).
RIP 1959-2015
Hello Alfred Welcome to the forum...:thumbsup:
I do not know if that would work.
They do make dimmers switches for dimmable LED'S.
RIP 1959-2015
What is the voltage rating on the lamps?
Most led lamps are 12v.
3 x 4w = 12w at 12v that's 1 amp.
Your 70w tranny easily has the current capacity.
But some electronic trannies require a minimum load to work
Be sure yours doesn't !
Thanks for the help guys :)
So if I have a 70w driver can I attach it to three 4W, 12V bulbs? The driver can be attached to up to three bulbs.
1 - 11 of 11 Posts
