Question
1677 Views 10 Replies 8 Participants Last post by  Celtic
What does 'Gang' mean with regards to switches?
1 - 11 of 11 Posts
1-gang box holds one switch; 2-gang box holds two switches; 2-gang box holds three switches and so on.
thanks chenley, i was told this was a friendly informative site.
It sure is, just not a DIY, We all help each other and learn.
Ah, 2 nations divided by a common language!:laughing:
In UK 'gang' is the number of actual 'switch mechanisms'
So 1 gang 2 way = 1 switch
2 gang 2 way = 1 switch
3 gang 2 way = 1 switch all of these will fit onto a single sozed mounting box / pattress
etcetera. We actually go up to 6 gang 2 way this would be 6 individual switches mounted on a double sized plate. Ater this we go on to modular grid switch systems:thumbsup:
2
1-gang box holds one switch; 2-gang box holds two switches; 3-gang box holds three switches and so on.
You sure?
:laughing:
OK try this.
One (1) gang holds one device in a rectangular box on a common yoke secured with 2-6/32" screws.
Two (2) gang holds two devices in a what is now a square box on a two yokes secured with 2-6/32" screws.
Three (3) gang holds three devices in a rectangular box on a 3 yokes secured with 2-6/32" screws.
Gangs
Good one Celtic :thumbup:
You sure?
:laughing:
I would say that is a 1-gang with a stack switch ;)
OK try this.
What if I use a 4S box with a single gang mud ring?
The box is square, the ring is square, but where the device goes is rectangular :blink:
1 - 11 of 11 Posts
