Just a question for you guys, I don't do much resi so I'm not too sure. A homeowner is looking at a new induction range and on the site of the range, the specs say range amperage - 52.5A then under that, it says minimum circuit size - 40A. Should I run a 50A circuit with #6 to be safe or do you think a 40A cct would be good?
Thanks in advance
Thanks in advance
