1 - 4 of 4 Posts
Hi all wondering if any one can help, I done a rcd test on a6 amp rcbo 30ma with no load circuit connected and my results where 310ms at 1 times and 50ms at 5 times.so I changed it thinking it was faulty so put the new 1 in tested it got the same results. Tested thethe other 1 in the board results fine.so has any 1 got any ideas what's going on. Also I done the rcd test on the 1I removed in my board at home and the results are fine. So can any 1 help me please cheers
Buzzy304E
Sparky, perhaps ask a moderator to relocate you Q to the UK section, most here won't even know what an RCD or RCBO are.
Good luck.
Buzzy304E
If you go into any section of the forum, click on the list of mods for that forum, I am guessing you will be able to follow the prompts. Also, just click on the red caution symbol in the lower left of your post to report it directly to a mod. Sooner or later,though, a mod will stumble on it and do it. Crack on!
1 - 4 of 4 Posts
