yes, you get to the jbox from the insideIs there a way to get into a recessed light when the drywall is up? I'm worried about something I wired...
LanceBass;Is there a way to get into a recessed light when the drywall is up? I'm worried about something I wired...
Push it up if you can. It gives you better access to the JB and, if you leave it hanging, the cheap ass flex connection to the can can come loose.yes the junction box on the fixture must remain accessible and on most fixtures there are three screws at the bottom of the can that will allow you to pull it down out of the hole for said access.
The only splice problem I have had is on the factory connection to the Wago. That's Halo "quality" for you.LanceBass;
Every splice you make up on the job MUST be ROCK SOLID, there are no mistakes.
Do it right 100% of the time, if you are told you are too slow it's because the faster guys are cutting corners hoping they do not get bagged.
LancedAss...LanceBass;
When I come across those I always do a double check push on the factory job.. often one of the wires will not be pushed in the wago very far. Def. worth taking the time to recheck those. Doing it after is a big pain in the arse and makes you look bad.The only splice problem I have had is on the factory connection to the Wago. That's Halo "quality" for you.
I cut those off and toss them, wire nuts are the way to go, however Lance may not have that choice.The only splice problem I have had is on the factory connection to the Wago. That's Halo "quality" for you.
That's why I like and prefer can lights. You can burn them at the rough in stage and check all your wiring plus it provides lighting for finish and it's the actual lighting. Nothing like working off halogen work stand lights then coming in and hang some lights to find paint or trim flaws that weren't apparent with the work lights.LanceBass said:Is there a way to get into a recessed light when the drywall is up? I'm worried about something I wired...
Wago's may be UL approved but if I worked for UL Wago's would not exist.
Yeah, it wasn't the splice it was me just having a mental error and wiring the lighting circuit incorrectly.LanceBass;
