I have one (forgot the brand) and it is great. You need to be mind full how it is put together at first and replace the blades at times. I will try to remember to post the manufactures name tomorrow.WHat do you fellas think about the adjustable Recessed light hole saw kit? Worth the $30 or is it junk?
Keyhole saw if it is drywall.WHat do you fellas think about the adjustable Recessed light hole saw kit? Worth the $30 or is it junk?
Can't see the brand from the pic but it looks just like mine. Mine is a Hole Pro and works great on drywall. But you do need to keep sharp blades or the holes get jagged looking after a while.I use one like this and it's pretty good... does a clean cut and keeps all the dust in the container.
Mine are becoming jagged, but the cans and trims still seem to cover it. Do you sharpen your blades or just buy new ones?Can't see the brand from the pic but it looks just like mine. Mine is a Hole Pro and works great on drywall. But you do need to keep sharp blades or the holes get jagged looking after a while.
Buy new, I think the blades are carbide and hard to sharpen.Mine are becoming jagged, but the cans and trims still seem to cover it. Do you sharpen your blades or just buy new ones?
I used to work for a guy who used one for a little while. After a couple of holes it would leave a ring on drop ceiling tiles.I use one like this and it's pretty good... does a clean cut and keeps all the dust in the container.
A little dark ring where the rubber touches the ceiling? yeah I've had that too.. gotta keep it clean and if it leaves a dark ring, just use a wet cloth to wipe it off.I used to work for a guy who used one for a little while. After a couple of holes it would leave a ring on drop ceiling tiles.
