1 - 9 of 9 Posts
A wise guy. Eh
Whoop whoop whoop
I only seem to find 100 volt. Will 24 volt operate it?
No voltage "operates" it. It's a switch. The voltage rating of the switch is the maximum voltage that can be applied to it. If it's rated for 100 volts (kind of an odd rating, I would imagine it's more like 125 volts) then using it on a 24 volt system is fine.
invictus said:
I'm looking for a recessed magnetic door switch for 24 volts. A webpage would b helpful Thanks for your help
. Recessed ( hidden ) magnetic door switch for what ? A security system , I'm assuming ? Sentrol and GE are two manufacturers I've used over the years on security jobs . Not sure if this is what you need , or a line voltage ( 125v ) plunger style switch ?
We install at least one in almost every house we wire.
what works best for me is a 4sq w/bracket box, the LVS snaps into a 1/2 KO we do the low volt wiring during rough-in. The door magnet is a bit tricky.. a 3/8 drill bit w/a dab of glue, wiring wise its staggered but splices. :thumbup:
1 - 9 of 9 Posts
