Thanks. My local supply house doesn't carry the one I have experience with. I could do one at each end but the homowner is looking for cheap as he is selling the house.That's a big room. Any chance you can do one at each end? The heat will be a little more even that way.
Using my normal rules of thumb, I'm calculating you'll need about 2200 watts of heat in that space.
Cadet and Marley are two popular brands of fan forced flush heaters. I'd probably use what the local HVAC or electrical supply house sells, though. They all suck about the same. It more or less comes down to price.
Wow 4800??! That's nuts. And a good price!This is the one I got Video Link: http://www.amazon.com/Qmark-LFK404-Fan-Forced-Wall-Heater/dp/B00064NV4C
Wires up to #12 240 volts and heats up to 4800 Watts. or 120 Volts 2000 Watts
Height is also important.finster said:Looking for reccomendations for a heater in a room 15x18 I have experience with king picawatt heaters and they go up to 2250 watts I believe. Any suggestions
Whoops! it's really 4000 Watts by the specs.Wow 4800??! That's nuts. And a good price!
Still that's sufficient for this space.Whoops! it's really 4000 Watts by the specs.![]()
