Status
Not open for further replies.
1 - 7 of 7 Posts
Hello,
I have a 100 foot long 110 v cord and it sees constant use here on the ranch. I note the outside plastic covering is beginning to fray and show age. It still works fine.
At the present cost of copper I simply do not want to replace this cord and I want to cover it to protect it from the elements.
Are you aware of any coating I could use to reinsulate this electrical cord from shorting out in the future?
Thank you for your attention in this matter.
Gene So
Coffee drinking member
Replace it with a quality cord or hire an electrician to locate receptacles closer to were you need them.
You only get electrocuted once in your life time and a bad cord isn't worth your life.
Reactions: guest
gene so said:
Hello,
Gene So
This has to be the biggest hack thread there is.
Donuts > Fried Eggs
Yeah, at most hardware stores they sell a sheathing material just for this purpose: It will usually work all the way up to 100' and it's UL listed.
I can't remember what it's called, but it also comes with two cord caps and it's pre-filled with copper conductors, but all you have to do is remove all that and you'll be in there like swimwear.
Thanks for posting on ElectricianTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
1 - 7 of 7 Posts
Status
