1 - 20 of 25 Posts
Senior Moment
Many years ago we ran out of indicator fuses in an Air Force Air Traffic Control facility and I took apart good conventional fuses and soldered in the "recycled" fuse wire into the blown indicator fuse bodies. The indicator fuses had a spring and when the fuse blew it would pop out a plunger that would close a contact to light a lamp.
Something like this?
If they haven't been exposed to ridiculous temps I wouldnt even think twice about using them. In fact I can't even say whether or not extreme temps would affect the fuse negatively
Are we recycling or reusing there's a difference
Why not fuses? Has the tech changed in 40 years? Does it wear out after 40 years? Breakers I am inclined to say "replace at 40", but not fuses.
Um... not sure we're all on the same page; the original question was about recycling fuses. Apparently Cooper Bussmann does have a recycling program; now I'm curious about our usage and might mention it to our environmental/safety guy.
My last post was talking about recycling blown fuses. If we decommission old equipment we will reuse anything that's worth saving, including good fuses; however, there are some fuses that are so old we no longer stock and they will get tossed.
Reactions: BuzzKill
No problem.
A couple metals I forgot to mention... we also have recycling bins for carbide, bronze, brass and EDM wire.
Last year we actually started composting at one of our facilities; we are planning on implementing that at another plant this year.
1 - 20 of 25 Posts
