We think it has a blown seal wont hold pressureIf it's the one with the hose, I just unscrew the fitting off the far end of the hose and squirt it in there.
Have you tried to order replacement seals for it?We think it has a blown seal wont hold pressure
Not yetHave you tried to order replacement seals for it?
Yeah, made a big ass messI have to look up the instructions every damn time I do it.
The last time, I ****ed around and made a big mess by sucking it in thru the small hole while pulling the handle up :jester:
Didn't see that line. The bottom cylinder looks like its not the reservoirUnscrew the bottom, it has a line inside that shows you the proper level for the oil
Sent from my SGH-I337M using electriciantalk.com mobile app
Borrowed toolDownload the manual from greenlee.
I think this is what was needed to be done. The screw from the bottom opening looks like the best way to get into the reservoir. The seals were not letting us build up any pressure though.If its the 767, hook up the ram, take cylinder screw cover off, take screw out from cylinder, fill with hydraulic oil and keep fluid over cylinder reservoir, while in upright position pump fluid into ram keep adding fluid to keep reservoir full. After ram is full let fluid back into reservoir and repeat a few times to bleed air out. After no more bubbles, reinstall screw. The key is to not let air get back into reservoir by letting fluid get below the filler hole.
Borrowed tool
It's a past employers tool. He let me borrow it thinking I could just refill, but the seals are blown. So even with a manual no can do. I don't own one larger than 2", ended up getting a large hand punch from a friend.Relevance? :001_huh:
Now that is just to easy to reply to. :laughing:The last time, I ****ed around and made a big mess by sucking it in thru the small hole.....
