Hi, it's been sometime since I have posted. I have a client that wants to have his 100A main panel to be relocated to the center area of his basement. It's in toronto detached house with overhead service.
Based on the code main panel should be as near as possible as the service entrance, but if I put a disconnect for 100A (breaker?) And run it from there to where the location my client wants the mechanical room (38ft from the disconnect) to be would be ok?
As a side note should I try to get an esa inspector first to verify he will approve it or is there a quicker online way that can be done with pictures once applied permit?
Thank you
