1 - 9 of 9 Posts
Estwing magic
Still being relatively new to this renovation game, I will ask a dumb question...
Just finishing a basement development with a dropped ceiling about 2" below the joists. What a PITA. I put in Halo H5TM's, standard new construction cans with T-bar clips, but it probably would have been easier and less time consuming to put in remodel cans. Any issues with this?
Slave to the grind
Unless the ceiling tiles are the heavy ones (like sheetrock) the tiles will sag down.
Yes they will sag in time.
You did it the correct way I'm thinking. T Bar and fixtures are a real pain. I personally would install the cans as normal and then drop the inside can down the required depth. The tile/ tbar holds no weight.
2" below the joists seems to be a lot for resi, must be a 9 or 10 foot ceiling down there.
I like ceiling fans & EMT
Remodel cans do not work well on a drop ceiling.
You can use remodel cans if you cut 2x2 squares of plywood and lay on top of the tiles, and hole saw through the tile/plywood and all.
(actually 23-7/8 x 23-7/8)
1 - 9 of 9 Posts
