1 - 12 of 12 Posts
Hello Guys,
I'm new in the forum. I have some doubts regarding the possible replacement of this bulb:
http://www.francelampes.com/e27-hi-spot-95-par30-230v-75w-30deg-halogen-sylvania-z-3496.html
I'm looking for a LED that would keep the same level of illumination as this model, because it concerns a beauty saloon and it's mandatory to keep the similar illumination intensity.
In your opinion, would this LED fit:
http://megamanlighting.com/led-ligh...flector/products/item/par38-15w-e27-30d-4000k
It has the same bean angle (30º), same fitting (e27) and same max lumen output (2200 cd), but different color temperature (2900K vs 4000k) and luminous flux (2000 vs 630 lm).
The problem is that it's a saloon and it's not possible to test just one lamp and check if the light conditions remains as before.
Thanks for your time and patience.
4000K is pretty white. They may not like it.
The 2900K is yellow and makes your face look quite nice.
I vote no for a beauty salon. You want the clients to look nice in the mirror. Maybe you can get a lower K replacement.
Color temp is ok (2800K).
Lumens are way down. We have that problem in Canada too. Dirt bag manufacturers say the bulb replaces 60 watt or something yet it puts out half the light.
Flex Bits & Blindfolds
In my opinion, it's not that LEDs aren't as bright or aren't an accurate replacement for halogen. They obviously don't have nearly the same color rendition. The real problem is that they don't seem to project light at all. Sure, if you look at the bulb, they're much bright and more intense than halogen, but by the time the light reaches the floor, even at eight feet, the lighting is nonexistent. LEDs are certainly more efficient, but if you factor in the light lost, is efficiency worth the loss in effectiveness? I for one don't think so, LEDs just aren't ready yet.
Thanks for the feedback:
The model i want to replace it's this one:
http://www.osram.com/osram_com/products/lamps/halogen-lamps/osram-halopar/osram-halopar-30/index.jsp
It informs color 2900 k(warm white) and useful luminious at 90º of 650 lm
Which means that at 30º and 2 meters distance, it will be less than 650 lm
I found this LED:
http://megamanlighting.com/led-ligh...flector/products/item/par38-15w-e27-30d-2800k
Which has 2800k color and 550 lm at 2 meter distance using 30º. So i presume, in terms of light intensity, this LED can provide the same (or more) amount of light than the previous halogen.
Other issue i find, is that this lamp is used in a saloon and would the LED provide the same color or it is better to choose a cold white(4000k) LED, to be sure to obtain a bright white color.
Thanks,
No, you want the 2800K light. This makes a person look like the cats ass. All warm and fuzzy.
That's why bars, lounges, pubs, etc. use a warm white (yellowish) light. That's so the babe in front of you looks like a sweetheart till the next morning when the sun hits her. Or maybe it's the booze.
White light has its place... parking lot lighting, on cars, office environments, etc. People-places and mirrors really want a softer light.
^^ My opinion.
1 - 12 of 12 Posts
