Oops.It's Canada
Funny how the Canadians can manage to figure it out. :laughing:Oops.
I only view threads using the "New Posts" button so I never know when it's a Canadian Forum question :laughing:
Your profile says you are a journeyman.Hey guys I had a cheat sheet for a load calc. but lost it does anyone know or have one they wanna share?
Thats 'cos we're not worried silly 'bout the whales and such. Pass the blubber brah.....Funny how the Canadians can manage to figure it out. :laughing:
That's horrible adviceIf it has electric heat it probably needs 200A service. No electric heat you probably can get by with a 100A service.
That's horrible advice.
You just said the same thing using different words. You have to consider building size and the connected loads, not just electric heat.I meant that as tongue in cheek, but for the most part if you put in gas heat you should be able to get by with a 100A service, if you put in an electric furnace you will end up needing 200A.
I'm not advocating skipping the load calc, because if the house is big enough, it could exceed 100A without electric heat and 200A with electric heat. And arbitrarily throwing those numbers down could be shortsighted. However, I do recall my first year instructor saying something similar to what you said.darren79 said:I meant that as tongue in cheek, but for the most part if you put in gas heat you should be able to get by with a 100A service, if you put in an electric furnace you will end up needing 200A.
There are lots of new 3000 sq ft and larger homes with only a 100 service.I can't even fathom putting in a 100 amp service in a new home.
Maybe an apartment but a free standing house?? no way.
900 square foot house with gas heat, stove, dryer and hwt. Why not?sbrn33 said:I can't even fathom putting in a 100 amp service in a new home. Maybe an apartment but a free standing house?? no way.
So what is your average cost to upgrade to 200A?There are lots of new 3000 sq ft and larger homes with only a 100 service.
It's amazing how easy it is for the homeowner to spend thousands of dollars on taps etc, but cry the blues when you want to upgrade to a 200 amp
Same thing happens when they buy their lighting. The cheaper the better![]()
