I am upgrading a electrical service to 200 amps. The service is overhead. I am planning to run conduit from the meter to the Panel along the siding and enter into the crawl space under the residence. It then will turn up into the bedroom to the panel which is next to the door. What i am not sure of is how far can the service entrance conductors run in the crawl space where it enters from outside to where it turns up to the panel. Right now it looks about 10 feet from where the SE conductors enter the crawl space to where it finally meets with the panel. There is no other place I can put the panel due to the stairwell, bathroom, Utility room with clearance issues and a gas meter also with clearance issues along that side of the residence. I am considering buying a meter with a disconnect in it but if I do so I won't be making much money on this project. Any info would be greatly appreciated.
