IMO...from the panel to the rod, AND, from the panel to the water pipe. Tying them is series isn't as good as parallel.Does it need to be a continuous run from ground rod to cold water pipe then into panel.Of course having a jumper over your water meter,also should we play it safe and just install 2 ground rods.
