Do you guys know if there is any difference in robroy and ocal pvc coated rigid?
I will get you the report that was sent out to us by a federal agency that did perform test on Ocal PVC GRC to back up their claim and I could not believe what I saw, it was pretty interesting to the extent and magnitude of the test describing each element that these conduits and fittings are exposed to. Don't believe what I am saying till I provide you with the memo sent out to us and other inspectors, revision of specs and issuing addendum for changes, so they want us to use T&B, Rob Roy but not Ocal.Interesting Giorgo. Ocal is pretty much all we use in CO. I used Rob Roy in NE years ago and I don't recall there being much difference. I would deffinately like to hear some more input.
No one ever does it correctly unless you have an inspector watching over your shoulders at all times unless you do spot checks at random threaded connections.I personally don't like Ocal. The coating is crap. Ever try to screw a factory thread into a condulet? One of our customers only allows Robroy. It is actually in the specs. The other option is Calbond, although I've never used any. FYI, most people are probably not installing PVC coated conduit correctly.
Absolutely no reason not to install per manufacturers recommendations. Our jobs specs require proper install and tooling.No one ever does it correctly unless you have an inspector watching over your shoulders at all times unless you do spot checks at random threaded connections.
Price is a big difference, I know that. Ocal is cheaper. Robroy is better quite on my opinion.RichardE310 said:Do you guys know if there is any difference in robroy and ocal pvc coated rigid?
It's not really that much cheaper, but yes, Robroy is better.Price is a big difference, I know that. Ocal is cheaper. Robroy is better quite on my opinion.
Maybe you've sold it, but have you ever installed it?I've sold both in the past and their almost identical in coating quality. My customers prefer Cal Conduits PVC coated, it's very good quality and the price is reasonable.
Last comparison I did was a Significant difference.sparky970 said:It's not really that much cheaper, but yes, Robroy is better.
3/4" for me is only about $2 a stick difference. We use Robroy sealtite fittings too. Talk about outrageous. Almost 20x the cost.Last comparison I did was a Significant difference.
I am digging it up from my files..................Hey Giorgio, I'd like to see the report too if you don't mind.
